Fiat Model Identification
Moderator: So Cal Mark
Postby 69Spider on Tue Nov 16, 2010 8:55 pm
IAP Website has a chart that matches the year and serial number of the car. What I was wondering is if this is accurate. I have seen two early Spiders recently that did not match year and serial number. In both cases the serial number was lower than the year, i.e. 1972 Spider should start at serial number 47032, but the serial number on this 1972 (registered as) is around 42000. IAP chart indicates that this should be a late production 1971. So what year is it (from a parts replacement point of view)?
I am sure you guys may have run into this before, please share your knowledge / experience.
Thanks.
Frank
Fiat Spider '71
Ford Mustang '69
Mazda Rx-7 '84
69Spider
Re: Fiat Model Identification
Postby Daniel on Tue Nov 16, 2010 11:37 pm
I'm not sure where you can go to cross reference this i saw a site sometime back possible german 124 forum
that had something going on to try and track the number of Fiat Spiders still on the road no ideal the name
of it, they might have a list of Vins . Have you tryd the other Suppliers or forums Mira would have some
people who might know, there are some hard core Fiat 124 enthusiasts on here as well i bet someone will
have information on this .
Daniel (the Bandit)
1979 Spider With a Completely Modified Stroker 2207cc Engine, Race Cams, TWM Side Drafts,
High Volume Oil Pump, SW Adjustable Cam Gears what a fun project can't wait to have her completed
Daniel
Postby So Cal Mark on Wed Nov 17, 2010 2:29 am
the problem is that back in those years the Europeans didn't have specific model years like the US manufacturers. They made running changes that are reflected in the serial numbers
Mark Allison
allisonsautomotive.com gear reduction starters for the 124, 131, X1/9, 850 Distributorless ignitions for 124, 131, X 1/9, Monza wheels
X1/9, 131, 124 Spider exhaust system, http://www.fiat500speed.com
Site Admin
Postby 69Spider on Wed Nov 17, 2010 1:06 pm
Here is a link to the IAP Chart:
http://www.international-auto.com/index ... =ad&aid=60
So if understand correctly, what you are saying is that for service / parts you would go by the serial number vs. the year registered. So for an early 1972, you may need to look at 1971 parts / specs. Please correct me if I am wrong. Thanks.
Frank
Fiat Spider '71
Ford Mustang '69
Mazda Rx-7 '84
69Spider
Postby mdrburchette on Wed Nov 17, 2010 2:23 pm
If you are ordering for a 71 or 72, they are basically identical so it shouldn't pose a problem.
mdrburchette
Postby mscafide on Wed Dec 08, 2010 5:58 pm
The earliest 1971's had 1438 engines.
Mike
1974 124 Spider
1964 500 D
2012 500 Sport
1948 Ford 8N tractor (restored (don't drink and ebay))
mscafide
Postby Dawgme85 on Fri Dec 10, 2010 10:08 pm
I suspect that the SN list is incorrect, as my son's 1970 BS (with dual lens side markers) is SN 25735.
It doesn't make sense that there were ~11000 1969's built, ~800 1970's, and ~25000 1971's. Could it be that the "1971" 1438's were actually 1970's? This would seem to add up correctly, though there were probably (as others have stated) a few late SN cars that were titled as the following model year.
Thankfully, parts for Spiders are (relatively) interchangeable.
Dawgme85
Return to Fiat Spider Related
Users browsing this forum: No registered users and 5 guests
