Convertible Top Strap Set Up
Moderator: So Cal Mark
Postby RedWolf on Sun Jan 29, 2012 10:48 am
I had my rear seat interior side panels replaced and recovered and have now lost the area where the "hole" should be drilled for the top boot hook as well as the placement of the 4 "bolts" for the top straps. Also, I've never really seen the straps used and was hoping someone may have a picture of how it fits both when used and when not in use. If anyone has some pics of the set up and some measurements where the bolts and hole should go - it would be much appreciated.
RedWolf
Re: Convertible Top Strap Set Up
Postby 124JOE on Sun Jan 29, 2012 1:25 pm
sorry i dont have any pics,but addvice "yes"
these cars were hand built
any mesurments would be aprox or close
feel down the back sides where the top goes when down
if you can feel the hole the hole then stick a nail throu from the back
when you do everything correct people arent sure youve done anything at all.
"how to post photos do a search!" photobucket/copy img code click it(copyed)then go to your post and (paste) to the post to topic or reply box. ;) joe ul1joe@yahoo.com
124JOE
Postby vandor on Sun Jan 29, 2012 11:19 pm
The straps fit on the top latches when the top is down. If your panels have no holes at all, then you could hook the top of the strap into the top latch, and see where the bottom ends up. Give it a little tension and drill a hole where the lower hook ends up.
Auto Ricambi, LLC, Fiat Spider Parts Specialists
http://www.autoricambi.us
vandor
Postby RedWolf on Mon Jan 30, 2012 6:26 pm
Thanks for the responses - I'll go w/the back up plan of pulling down the boot and marking the spot for the hole (the panel was replaced w/a custom cut job so it doesn't have the holes). I think I can pull the straps into place and mark where those go as well.
I know the type of bolt to use for the strap with the "roundish" end; for the square end of the strap when it's not in use (convertible top up) to affix to the back interior panel - do you use the same type of bolt w/the screw in the middle? I think I must have gained an extra type of this kind of screw/bolt as I have 5 of them.
RedWolf
Postby vandor on Tue Jan 31, 2012 11:12 am
RedWolf wrote:I know the type of bolt to use for the strap with the "roundish" end; for the square end of the strap when it's not in use (convertible top up) to affix to the back interior panel - do you use the same type of bolt w/the screw in the middle?
Yes.
vandor
Postby GTO on Wed Feb 08, 2012 9:38 am
Bit late but this link might help.
viewtopic.php?f=15&t=12543
GTO
Return to Fiat Spider Related
Users browsing this forum: tartan18 and 4 guests
