HELP is this OK?
geospider
HELP is this OK?
Postby geospider » Sun Oct 08, 2017 8:03 pm
with AR springs: all bolted up: all shims replaced as before.
has this unloaded camber: is this OK. the edge of the upper control arm hits the brake shield and the brake caliper won't go on: hits the steering arm.
will it all change when loaded. If so, I will need to put the rest with jack under lower control arm. haven't seen or read anything like this on any threads.
THANKS TO ALL WHO KNOW MORE
Geo
Contact:
Re: HELP is this OK?
Postby RRoller123 » Sun Oct 08, 2017 8:17 pm
That does not look at all right. I think something is incorrectly assembled. Compare to other side?
'80 FI Spider 2000 (rolling "resto")
'74 X1/9 (many years ago)
'79 X1/9 (fewer years ago)
'86 Jaguar XJ6 (2nd Hobby Car)
2010 Chevy Silverado 2500HD Ext Cab 4WD/SB
2015 Keystone Montana High Country 343RL
geospider
Postby geospider » Sun Oct 08, 2017 8:22 pm
other side is the same
everything went back on the way it came off. all new ball jts, bushings, etc
original control arms. only change was springs and Koni shocks
geospider
Postby geospider » Sun Oct 08, 2017 8:44 pm
well, I figured out part of it.
and worst part is I looked at this over and over: the knuckle is upside down: stupid; like I wanted to do all of this again.
I don't think that would change the camber: length of knuckle is unchanged.
I think every time I post I feel more brainless
Please tell me thats it
DRUMMOND
Postby DRUMMOND » Sun Oct 08, 2017 10:17 pm
Looks like you have it upside down? longer neck belongs on the top, yours looks like it is on the bottom
lglade
Postby lglade » Sun Oct 08, 2017 11:34 pm
We've all been there...we think that we'll remember how we took something apart or that it can only go back together one way...only to get burned later. Sometimes life gets in the way and we can't reassemble for several weeks (memory fades), or there are multiple ways to re-assemble a component (with only one correct way).
Anymore, I just make it a habit to take several pictures of all major assemblies as I remove and disassemble them...or I'll use masking tape on parts to indicate things like left/right, up/down, fore/aft, inboard/outboard. It's saved me several times.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
geospider
Postby geospider » Sun Oct 08, 2017 11:39 pm
thanks all. yep upside down. another objective look proved that.
I "thought" I had everything taken off and put in separate boxes, etc. and yes awhile between taking apart and reassembly
pretty sure R and L for these are the same, so ball jts apart and flip. unless I am wrong there too
geospider
Postby geospider » Sun Oct 08, 2017 11:44 pm
correction: R and L not the same: I do have them on the correct sides: as I re did the hub bearings and the R and L hand threading is correct.
gotta stop trying to think when the sun goes down. or maybe its the beer
DieselSpider
Postby DieselSpider » Mon Oct 09, 2017 1:51 pm
I saved my old cell phone to use as a garage camera to help my memory when putting things back together. It remembers things a whole lot better than I do.
geospider
Postby geospider » Sat Oct 14, 2017 6:46 pm
was actually an easy job. but I need new spindle nuts now.
quite a difference.
before (drivers side)
after (pass side)
thanks guys.
geo
Now if I could just get my son's Explorer running it will be a good day
Return to “Suspension Related”
Users browsing this forum: No registered users and 1 guest
