Fuel seeping from Weber mixture screw.
MIGHTY 8
Your car is a: 1980 Spider
Postby MIGHTY 8 » Fri Feb 02, 2018 2:23 pm
Hi,
Noticed a seep (and Occasional drip) from 3 mixture screws after driving car. Last one towards the rear was perfectly dry.
I also noticed that after starting the engine, the problem corrected itself on two of the three mixture screws after running for a few minutes.
Any help greatly appreciated
Nut124
Re: Fuel seeping from Weber mixture screw.
Postby Nut124 » Fri Feb 02, 2018 3:11 pm
Replace the O-ring on the screw shank.
Nut124
sptcoupe
Your car is a: 1972 124 Sport Coupe
Postby sptcoupe » Sun Feb 11, 2018 11:13 am
Check you float levels, and make sure the fuel pressure is regulated at 2.5psi.
sptcoupe
Postby sptcoupe » Sun Feb 11, 2018 11:16 am
And while you have the carb tops off, check the size of the needle valves (should be 175 or 200), and make sure they move freely.
Return to “Performance”
Users browsing this forum: No registered users and 1 guest
