Transmission Mount and Bracket Removal
opamp
Your car is a: 1980 Fiat Spider 2000 FI
Re: Transmission Mount and Bracket Removal
Postby opamp » Sun Jan 14, 2018 4:36 pm
alsgro wrote:By the relative silence on this thread, I'm judging that the job is a real PITA! Probably gonna have to remove the guibo and driveshaft at least...?
I'm kind of guessing so--I may go ahead and do that anyway since I have the replacement parts on hand already from some transmission work I had planned...not sure how soon I'll get to this, but if I do--I'll snap as many photos as possible...I wish I had a lift.
DRUMMOND
Postby DRUMMOND » Sun Jan 14, 2018 10:03 pm
Hi Opamp
you don't need to take the quibo or the driveshaft out to replace the transmission support rubber.
But you do need enough height to get to the bolts. make sure your gearbox is in neutral and you have an offset ratchet wrench 17mm I believe. you can then undo each bolt head and turn the shaft to get to the next one, remember the support only goes on one way (it has a long ear and a short ear) make sure you take before photos so you can remember how it goes back together.
have fun!
opamp
Postby opamp » Tue Jan 16, 2018 8:05 pm
DRUMMOND wrote:Hi Opamp
have fun!
Brilliant--I think you've probably just saved me hours of frustration with these three sentences! I'll report back when I get into this fix.
Ragno124
Your car is a: 1981 124 Spider
Postby Ragno124 » Wed Jan 17, 2018 9:13 am
This short video might be helpful...
https://www.youtube.com/watch?v=cMAYPzd_VXQ
Steve Muzzillo
1981 124 Spider 2000 (ex-turbo)
2006 Acura MDX
2008 Honda CRV
2014 GMC Acadia
2017 Acura RDX
geospider
Postby geospider » Sat Jan 20, 2018 1:12 pm
As I recall, the mount first is installed onto the cross member given the design of the cross member, then set in place.
I put a jack under the trans, you have a bit of play. I do remember having to muscle up to get it all in place, but then it went pretty easily. I think I used a ratcheting box end; they have enough offset to get to the nuts. Although I have done so much since, it is hard to remember.
Geo
geospider
Postby geospider » Sat Jan 20, 2018 1:14 pm
Well, you could slide it up in place. But I was missing a bolt, nut and sleeve on the crossmember to mount. And I was then able to clean and repaint. If yours looks good, could just do the mount. Again easy to forget when a lot has been done.
Good luck
alsgro
Postby alsgro » Sat Jan 20, 2018 2:52 pm
These are awesome tips. Hitting mine on Monday hopefully. I’ll keep you guys posted.
opamp
Postby opamp » Mon Jan 22, 2018 8:56 pm
Yes! Thanks so much everyone--now I am not so scared to dive into this...
alsgro
Postby alsgro » Thu Jan 25, 2018 11:26 pm
For anyone interested, I did this job earlier in the week. I was able to change the rear mount without removing the drive shaft, but I did have a heck of a time getting it off. In fact, since the rubber was already dead and gooey, I ended up cutting through the old mount in order to remove that bottom bracket and make enough room to get a wrench in there. PITA!!!! I tell you!
It would help to remove what I think is probably the switch for reverse. Mine wouldn't budge, so it made the whole ordeal a drag.
Once I got the old one out, the new mount went in quickly.
geospider
Postby geospider » Sat Jan 27, 2018 11:13 am
Glad you got it done.
Every new job done is a learning experience.
you get to know these cars very well as we go along.
I now know the front suspension and steering better than on any car.
Geo
Kongphooey
Postby Kongphooey » Mon Feb 19, 2018 4:49 pm
Great tips. Quick question...in the photo above are there supposed to be any bushings, rubber washers or the like between the cross memeber and the body? Seems like there should be but we didn't have any when we removed ours. Thanks
alsgro
Postby alsgro » Mon Feb 19, 2018 4:58 pm
Nah. At least there weren't any when I took mine off. Washers on the underside of the bracket, but nothing btwn the bracket and the body.
... U guess they figured the rubber incorporated into the mount was enough??
blazingspider
Your car is a: 1977 fiat spider
Postby blazingspider » Tue Feb 20, 2018 6:23 am
There are supposed to be rubber grommets with spacers that fit in the holes used to bolt the transmission mount to the body.
geospider
Postby geospider » Wed Feb 21, 2018 4:36 pm
If there are, there weren't any on mine. And given the look of the gooey rubber on the mount, I am guessing original.
Not sure what the manual says since I didn;t use it for this job.
Return to “Fiat Spider Related”
Users browsing this forum: No registered users and 30 guests
