Hello,
I am about on install a new 32/36 tomorrow on my 78 Fiat (no smog).
Just curious if anyone can ID this nipple... do I leave it as is, plug it?
Also, how do I hook up the electric choke? I have already re-routed the water back to the block.
Is it as simple as pulling the electric connection from the old carb (32adfa) and hooking up to the new carb? See old carb below, thanks everyone!!!!
32/36 DFEV - ID this port please
- Your car is a: 1978 Fiat Spider
78 Fiat 124
- 70spider
- Your car is a: 1970 Fiat spider
Re: 32/36 DFEV - ID this port please
I am no expert, but on my 1438 motor I simply plugged it and the carb ran fine.
2002 Mazda Protege5
2013 Buddy 170i
2002 Mazda Protege5
2013 Buddy 170i
So further digging, the connector on the 32adfa is the "idle stop solenoid" - and this should be a good source for the electric choke?
78 Fiat 124
70spider wrote:I am no expert, but on my 1438 motor I simply plugged it and the carb ran fine.
I believe this is a "vacuum advance port for the dizzy". Since I switched to a Fireball electric ignition, can I plug the port?
78 Fiat 124
Also - does anyone know the linkage ball size g5 or 8mm) Looks like the stock rod is about 1” to long (10” need 9”)
78 Fiat 124
- phaetn
- Your car is a: 1974 Fiat Spider 1800
Well, yours looks a little different than my EMPI 32/36 DFEV, likely because of your fancy fuel line intake. Mine's just rubber hose with a clamp.
On mine, that port you point to just has a hose that goes to the top of the charcoal canister.
As for the electric choke, it just requires 12v that is only is hot with ignition. Under that yellow cap is a bimetalic coil that expand/contracts with temp. You can twist the cap with affects the coil position. It should be set so that when the engine is stone cold that the choke butterfly valves are almost (but not fully) closed in the carb throat-- some use a credit card thickness as an acceptable gap. Once the 12v line is hot (e.g. with ignition on), it will gradually cause the butterfly valves to open. They should be fully open within about a minute or so and stay that way during operation.
Check out how it works with the lunchbox air filter off first. It can be a pain to get at those screws when the carb is in place because the hard brake lines off the master cylinder can get in the way, but you'll get the hang of it.
Hope this helps!
phaetn
Hope this helps!
phaetn
Looks like the ball socket is 8mm if anyone is curious
78 Fiat 124
phaetn wrote:Well, yours looks a little different than my EMPI 32/36 DFEV, likely because of your fancy fuel line intake. Mine's just rubber hose with a clamp.
Hope this helps!
phaetn
Thanks for the big heads up! That’s an awesome description too...
BTW, I added the AN fitting for my return line. Just got to tap the supply side now.
So will the wire from the original carb suffice?
78 Fiat 124
architect wrote:phaetn wrote:Well, yours looks a little different than my EMPI 32/36 DFEV, likely because of your fancy fuel line intake. Mine's just rubber hose with a clamp.
Hope this helps!
phaetn
So will the wire from the original carb suffice (idle stop silonod)?
78 Fiat 124
- phaetn
I would think the original wire would suffice, but it depends on how it operates and when it's getting power. Check with a voltmeter if it is getting +12v; you only want it to get power when ignition is on. It's the heat from the electrical wire that causes the bimetalic coil to expand and shift the choke valve positioning.
phaetn
Users browsing this forum: Google [Bot] and 20 guests
