You can see from this picture that there is a plugged hole in the base of the air filter. (Note that this is an old photo with my old "Frankenstein" carburetor. The new one is a Chinese 34 ADF copy.)
And the metal fitting for the hose has a second, smaller connector which is presently not use, and not plugged.
So, here are the questions:
- 1. Should I try to route the hose through the plugged hole under the air filter base plate? This would have it skip the filter entirely and dump the hose exhaust right into the carb. This would hopefully most likely eliminate any exhaust from leaking into the atmosphere.
- 2. As suggested in previous posts (from my old carburetor, which was a Frankenstein model with weird stuff going on), should I connect the "other" connection of hose bracket into one of the currently plugged port in the carb? See http://www.fiatspider.com/f15/viewtopic.php?f=5&t=30934&hilit=breather#p241899. (Again, note that that post referred to my old carb which was ported differently.)
- 3. Can I skip this entirely and connect the breather to a filter like this https://smile.amazon.com/62-1600RD-Vent-Air-Filter-Breather/dp/B009774GCA/ref=pd_sbs_263_1?_encoding=UTF8&pd_rd_i=B009774GCA&pd_rd_r=315C1K9QE6J4C98WFNFS&pd_rd_w=Liey2&pd_rd_wg=RzZP4&psc=1&refRID=315C1K9QE6J4C98WFNFS?
- 4. Am I barking up the wrong tree here?
Thanks!
