In the middle of an engine rebuild so engine and trans were pulled from car. Engine is fresh and regasketed trans but nothing more. Reinstalled in car. The trans is a 5 speed in a 78 Spider.
The trans shifts into 3-4 and 5-R fine but will not go into 1-2. I figure the problem must be the selector in the top cover and the dogs in the fork shaft. I dropped the bottom cover and everything looks like it should be lined up. All forks and sleeves are centered between gears and prop shaft turns freely. It just won’t engage 1-2.
Any ideas or tricks I don’t know about?
Trans Will Not Go into 1st or 2nd Gear
- Your car is a: 1978 Spider
- Nanonevol
Re: Trans Will Not Go into 1st or 2nd Gear
I believe this can often be due to wear on the shift forks and adjacent parts.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
Users browsing this forum: No registered users and 14 guests
