Something about posting the pictures....the right side gets cut off
I've been thinking the same, I have actually bought myself a 15" fiat space saver tyre to give me the room..4uall wrote:Ditto on the no bolt for the spare tire. When my wife bought her new RVR the spare tire and tools are actually in a Styrofoam insert. It got me to thinking that maybe I could fabricate some sort of inserts for mine as well
I pulled the center console this afternoon. I can't see how that piece works on a 124! There are no holes that match with those on the piece and the circle seems to be to0 small to allow for the full throws of the shifter.Exit98 wrote:Jay,
The second item is the inner shift plate. If you remove the wood on the lower console, that's where you should find one of those. If it isn't there you'll be looking at the top of your transmission. Lot's of noise and heat in the cabin.
