Part numbers
juvius
Your car is a: 79 spider
Part numbers
Post by juvius »
Does anyone here have the ability to look up part numbers? I've been googling all day and can't really figure out what's what. If you don't mind looking, i can pm or email the part numbers.
thanks,
steve
danaspider
Your car is a: 1979 Spider 2000 79 vw bus
Re: Part numbers
Post by danaspider »
go to the Vicks auto web site or IAP and view the parts catalogs on line. I know you can down load the one on Vicks. Should be able to find what you need from there.
Luck Dana
79 Spider 2000
carb
It all about the romace of the car and owner
juvius
Re: Part numbers
Post by juvius »
thanks.. i was on vicks, but i was just typing the part numbers into their search. i'll check out for a download...
juvius
Re: Part numbers
Post by juvius »
catalog didn't have the numbers i'm looking for. thanks again
Re: Part numbers
post your part numbers
juvius
Re: Part numbers
Post by juvius »
So Cal Mark wrote:post your part numbers
thanks mark... it's a big list, i'm trying to figure out what all this stuff i have goes to, so i know what i need to keep.
also, one of the cam towers i have has a double pulley on it - what's that for?
4226587
4232871
4158644 6a
4158644 1a
4318102 1a
4158643 2a
4328401 6b
4272859
4268804
4150654
4151267
4315860
4uall
Re: Part numbers
Post by 4uall »
juvius
Re: Part numbers
Post by juvius »
4uall wrote:would this help? :?
http://www.spiderroadster.com/index5.htm
i'm checking it out.. so far i haven't match any numbers... thanks
Ramzi
Re: Part numbers
Post by Ramzi »
These look like casting numbers from a 1608 or 1438 head assembly and intake to me
Ramzi
juvius
Re: Part numbers
Post by juvius »
Ramzi wrote:These look like casting numbers from a 1608 or 1438 head assembly and intake to me
Ramzi
i have two 2000 heads, either a 1438 or 1608 head (haven't figured it out yet - 4232871), and an 1800 head. i have limited space and i managed to mix everything up. I just want to make sure i have the right valves to go on the 1800 head that i'm putting on the 2000 block....
Re: Part numbers
valves are all the same between heads
juvius
Re: Part numbers
Post by juvius »
So Cal Mark wrote:valves are all the same between heads
thanks. i guess i was over complicating it, as i usually do. Any idea why one of them has that thick pulley for two belts? I'm just curious what the extra belt ran.
fiat218
Re: Part numbers
Post by fiat218 »
Prolly just a safety reasons, or maybe something eles ran off that pulley too
redcars
Re: Part numbers
Post by redcars »
The double pulley for the cam goes on the exhaust and runs the air pump. when that air pump locks up it tends to break the timing belt and there goes your head.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
