Anyone know what these are?
juvius
Your car is a: 79 spider
Post by juvius »
I have come across a few things that i can't remember where they go. Do any of you know what they are and where they go? i'm not even sure if it's all fiat stuff. i may have mixed some stuff in my boxes on accident
thanks
wizard124
Re: Anyone know what these are?
Post by wizard124 »
#2....fire wall grommet for throttle cable??!!
The others don't look familiar to me
Warren
juvius
Post by juvius »
wizard124 wrote:#2....fire wall grommet for throttle cable??!!
Warren
Thanks Warren....
Post by AriK »
If that's the only parts you were left over with after your build i bow to you, sir :)
FiatMac
Post by FiatMac »
#1- Stops in the seat slider tracks to limit backward travel?
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
83 parts car
juvius
Post by juvius »
FiatMac wrote:#1- Stops in the seat slider tracks to limit backward travel?
Thank you. Two down... Three to go
vandor
Post by vandor »
Yes, number 1 does bolt to the set rail, but I don't remember exactly how. Number 2 is the firewall grommet and bushing for the early throttle linkage.
Number 5 is a spacer that goes where the steering column mount bolts the cross brace.
vandor
Post by vandor »
Number 4 goes on the 78-on reverse light switch to hold the wires.
juvius
Post by juvius »
vandor wrote:Yes, number 1 does bolt to the set rail, but I don't remember exactly how. Number 2 is the firewall grommet and bushing for the early throttle linkage.
Number 5 is a spacer that goes where the steering column mount bolts the cross race.
Thanks crabs.
Dang auto correct.... Sorry csaba, that was supposed to say:
Thanks csaba....
juvius
Post by juvius »
AriK wrote:If that's the only parts you were left over with after your build i bow to you, sir :)
Not done putting it together yet.... These are just the things I didn't know what to do with.... I'll have a lot of leftovers. A have two buckets of nuts and bolts from 8 rusty spider I tore down...
Post by AriK »
Hope you resume your project soon, work out all the ins and outs and finally get behind the wheel :)
Frog2Spider
Post by Frog2Spider »
# 5 may be a door hinge back support, and # 4 a hose connector.
Frog2Spider
'81 - 2000 Spider
