I've taken the cover off of the AFM and checked that the contacts "make" when the flap is moved, they are contacting, but no pump running like it should. The ground in the trunk is good, the grounds on the plenum are good. I will check if the ignition switch is passing power to the control circuit. It does crank the starter, but no power to the pump and injectors as I said.
Thanks a bunch John, I'm trying the things you suggest that are new ideas.
Ron
