Can anyone identify this mystery washer
christopher707
Your car is a: 1974 Fiat 124
Post by christopher707 »
Hello:
I am on the last item of a 5 year restoration of a 74 spider, Gelsomina. I am reattaching my convertible top frame and have two
thick washers that I can not find where they go. I have them in the same bag with my top mounting hardware. Actually I have two bags because I bought two spiders and made one. Here is an image:
Any info would be appreciated. Just wanna put them where they belong.
DRUMMOND
Re: Can anyone identify this mystery washer
Post by DRUMMOND »
Hi Christopher 707
I am not sure if I remember correctly but I think they are spacers for the main hood spar behind the door pillar. I have the same two washers in my top frame parts but I have not installed my roof for a few years. so memory may not be correct
christopher707
Thank you for responding. Thats what I am thinking also, but there are only 2 countersunk allen screws on each side and the metal frame holes are countersunk tappered so i am thinking spacer as well. Problem is that frame fits in there pretty tight already, and there were only 2 spacers, would think two on each side to keep it even. Ive looked thru my three manuals and online for an exploded view but have not found one as of yet.
Best Regards
I think the washer fits between the lower mounting hole and the threaded floating piece. If you put the counter sunk screws in I think the top one has the floating thread close to the opening and the lower one has a space for the washer.
christopher707
Hmmm..that sounds right. I'll give it a try. Thanks
cos
Your car is a: 1978 cs2 spider
Post by cos »
christopher707 wrote:Thank you for responding. Thats what I am thinking also, but there are only 2 countersunk allen screws on each side and the metal frame holes are countersunk tappered so i am thinking spacer as well. Problem is that frame fits in there pretty tight already, and there were only 2 spacers, would think two on each side to keep it even. Ive looked thru my three manuals and online for an exploded view but have not found one as of yet.
Best Regards
Keep us posted with this as i have 2 spare washers as in your photo from the frame, and was wondering where these go!
DRUMMOND
Post by DRUMMOND »
Excerpt from Workshop manual for hood frame
Lift flap (3) out of way.
Mark position of frame mount bracket (1) for reinstallation.
Remove two allen head bolts (2) on each frame mount.
Remove entire top assembly by lifting up at rear bars Note
location and number of spacers behind frame mounts.
[/color][/color][/color]l 1. Frame mount bracket 2. Allen head bolt 3. Protective flap
