HELP
toplessexpat
Your car is a: 1976 Spider 1800
Re: HELP
Post by toplessexpat »
Here's Brad's diagrams:
http://www.artigue.com/fiatcontent/Wiring_1980_1982.pdf
Like magicwrench says don't go messing with wires etc. But - I would get on my hands and knees and gently look inside the ignition switch wiring and see if anything is charred etc. Take a look under the hood, gently look inside wiring looms and see if there's any tell-tale molten plastic (even if working fine).
I knew a guy who accidentally arc'd the alternator stud over onto an inadvertently stripped piece of wiring and melted the wiring back into the main loom.... and then spent a long time unpicking it all before replacing the molten piece.
Just because it's running (and we hope it is!) it doesn't mean it's fixed.
A
Many classic Fiats - it's a disease!
www.mirafiori.com
Fiatracertracer
Your car is a: 1982 Fiat Spider - Lip Stick Red
Re: HELP
Post by Fiatracertracer »
Holy Cow...... magicwrench is right.
The Autozone guys didn' know what they were talking about. I decided to get it inspected by a qualified alternator rebuild shop and they determined that the alternator was good. It was putting out 13.65 v. I will check the fuse when I get home.
I am so grateful, Thank you.
1982 Fiat Spider in restoration
Fiatracertracer
Re: HELP
Well everything is back together and she started right up.
Everything works except for the rear brake lights, soldered the boards but still no lights.
4uall
Re: HELP
Post by 4uall »
Re: HELP
The brake light switch is located on the brake peddle bracket. It has a white and a red wire going to it. The white wire gets voltage from fuse 1 (A) the red wire goes to the lights. Have you checked voltage at the switch??
toplessexpat
Re: HELP
.... page 4 in Brad's diagram :)
www.mirafiori.com
Fiatracertracer
Re: HELP
OK found it and removed it, tested it with a meter and it failed. Installing a new one tonight.
Fiatracertracer
Re: HELP
OK, I replaced the switch and all is well.
Re: HELP
Wow it's great when someone has the fortitude to sick with a series of issues and find success.
remember: If you feel you are going through Hell, keep going. its the only way out. You made it.
Fiatracertracer
Re: HELP
Yes, I did make it out and thank you for all your help.
