Page 3 of 3
Re: TIPS
Posted: Tue Aug 28, 2012 10:27 am
by FiatBen
Re: TIPS
Posted: Tue Aug 28, 2012 11:28 am
by baltobernie
124JOE wrote:... use butane to fill the cans air space so it wont cure in the can
I looked it up; butane is heavier than air. So we don't need to fill the POR-15 can completely, do we? A butane "barrier layer" will be sufficient?
I have portioned it out into baby food jars, but your idea is better.
Re: TIPS
Posted: Tue Aug 28, 2012 4:41 pm
by giuliot60
POR-15 is a rust coating Ron
Re: TIPS
Posted: Tue Aug 28, 2012 5:01 pm
by fiat218
rontron2012 wrote:124JOE wrote:if you used POR15 and you have some left over
also use wax paper to keep the can and lid from sealing together
what is POR15?
Rust treatment, that all I know, look it up and u will get a better understanding, better then I can explain
Re: TIPS
Posted: Tue Aug 28, 2012 6:39 pm
by 81SPIDERMATT
If you do not know something.... ASK.... you are in fact on the greatest site in the known universe
it will save time and much frustration
Re: TIPS
Posted: Tue Aug 28, 2012 6:48 pm
by fiat218
81SPIDERMATT wrote:If you do not know something.... ASK.... you are in fact on the greatest site in the known universe
I will 2nd that
Re: TIPS
Posted: Thu Aug 30, 2012 12:19 am
by blurple124
When replacing sway bar bushings, you will have some trouble with the inner brackets.
In order to get them apart, you will have to drill the rivets out with a 1/2" drill bit.
To get them back together, put the bushing in place, then put the brackets around it and slip a 1/2" diameter bolt through each side and use them to compress the bracket around the shock. Once fully compressed, tack-weld the brackets together. Remove your bolts and voila!!
I don't have a good trick for the ends yet, but a C clamp seemed to work fairly well
