Edit... Resto mod FIRST DRIVE
- toplessexpat
Re: Edit... Resto mod coming together
That's because he's taking pictures for our Australian contingent...
- Your car is a: 79 spider
that has to be it....toplessexpat wrote:That's because he's taking pictures for our Australian contingent...
"Having friends with the same mental disorder"
PRICELESS!!!
PRICELESS!!!
- Ptoneill
That's ok wait until he installs the Fallopian tube to the heater core!?........that was a classic for the new guys on the submarine I was on.
Stay Safe,
Pat
79spider
HAVE FUN!! It's a FIAT!!
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
on the uss princeton, we liked to send them for an HT punch or a board stretcherPtoneill wrote:That's ok wait until he installs the Fallopian tube to the heater core!?........that was a classic for the new guys on the submarine I was on.
- toplessexpat
Following this line.... on the Spider.... we should be recommending that people replace their Rear Guibo then?
A
A
Ahhh, you guys are too much!!
Ok, I cut the brackets back off and tested a few new locations. A bit of angle seemed to work best
So I spot welded both sides and tested bottom
And top
No binding within the reach of the shock.
Then just to be sure all is well, a installed the upper arm and checked again
Looks like it will work. Now I have to take it all back out since I am using a spare cross member and my engine assembly needs to be in for final install.
And top
- toplessexpat
Looks like you've got it cracked.... Any room for one of these too? http://www.ebay.com/itm/281388343671
If it doesn't block my 3rd brake light... Hell yea, right on the deck lid...NOT
Tomorrow I will start modifying my rear end to accept a second guibo!!!
Your rear is bad huh,SoFlaFiat wrote:Tomorrow I will start modifying my rear end to accept a second guibo!!!
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- toplessexpat
.... it's the future...SoFlaFiat wrote:Tomorrow I will start modifying my rear end to accept a second guibo!!!
- Your car is a: 1982 F I spider
Looks great, can't see in the picture but do you have either tapered washers or spacers on each side of the heim joint. Used to make sure when the joint moves thru it's travel, the ball part of the joint does not hit the through bolt.
Made up similiar for a rear sway bar.
Thanks, Rick
Thanks, Rick
Thanks Rick!
They have tapered spacers.
Here's a better picture
- Ptoneill
Ok, I love the engineering that went into these,,,,they look great, but what makes them different than the bolt on style I used? I can see that they are adjustable but I have no race/suspension design experience. Thanks
Stay Safe,
Pat
79spider
ptoneill@msn.com
Pat
79spider
ptoneill@msn.com
