Cam/Valve Cover
halg
Cam/Valve Cover
Post by halg »
Was there any year or model of Twin Cam engine that would have the oil fill at the front of the drivers side cover?
Hal
Daniel
Re: Cam/Valve Cover
Post by Daniel »
Hi Hal
I think if you want one like that you need to look for lancia valve covers
Re: Cam/Valve Cover
I haven't seen any of the Fiat versions with the oil fill on the front left corner
manoa matt
Re: Cam/Valve Cover
Post by manoa matt »
Are you going distributorless? Use two covers without the fill hole and use the distributor hole as the oil fill hole. Taking the plug out once every three months should not be too big of a hassle and should clean things up a bit. Makes people wonder "Where does the oil go?"
