what carb is this
what carb is this
from a 1980 2000, smog pump
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
Re: what carb is this
its a bit hard to say because we need to see the back top part as well
to me,you say its off a 80 so that would make it a adha 28/32
im looking for that vacume addvance thing to say yes thats it.
the 80 also has color vac lines
vac-um advance on the dizzy?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
im sorry the vacume seconaryfiat218 wrote:vac-um advance on the dizzy?
No, he's referring to the big vacuum diaphragm that opens the secondary.
I think I see it hiding back there. I agree that it looks like an ADHA 28/32
Joel
Joel
thanks, next question. i can remove that carb and manifold and stick on a 1800 manifold / correct? and differnt carb
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
yes
and a 32/36 on a 1800 intake is good power
also you can go FI if you pockets are full
Check the emission standards first. If the car has to meet standards be careful what you do to it. If no standards ditch that carb and manifold and replace with 1800 manifold and better carb.
no emission in northdakota/ ok next question. i have a 1800. what carb?
thanks for all your help
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- 124JOE
so cal mark
sells a empi 32/36
for $255 and 16 for shiping
sells a empi 32/36
It might be a little bit more to buy it from mark, but if you have any questions about the install he will help you figure it out.
If you want to save a few bucks take a look here
http://www.webercarbsdirect.com/category_s/696.htm
Joel
Joel
money is no object. thanks for all the info
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
