Anyway, this is pretty new territory for me so does anyone know of something I can read to get me up to speed on the subject? I can, however, fix the carb on my lawn mower.
Will check this eveing.124JOE wrote:how is your choke?
is is moving to closed?it my be too warm outside
you can leave the car off and check your setings
Yeah, I was just hopeing to fix it before I purchased a rebuild kit from you. Because after I rebuild it, I will then have to take it to a mechanic for the second, correct rebuild.vandor wrote:If it floods then likely that is not an adjustment issue! I suppose the float level could be off, but it's not something that changes by itself.
Sounds like the carb needs a rebuild.
Hey! That's my plan too!Because after I rebuild it, I will then have to take it to a mechanic for the second, correct rebuild.
I did replace all the fuel hoses and it did improve the carb performance a lot.blurple124 wrote:An easy place to start would be to check all of your engine hoses.
Just west of Houston.dmwhiteoak wrote:Where is Katy anyway, is that just north of Houston?
What vaccume hoses are you referring to?jsab wrote:You need to check the vacuum hoses and system also, holes in these will also cause backfiring on deceleration
Perminently open. Will not close. It's a water choke so I bet it's rusted.124JOE wrote:how is your choke?
majicwrench wrote:Backfiring on decell is not really a big issue, and may, or may not be carb related.
