Torx Seat Bolts RESOLVED :-P
would anyone know the size/measurements of the torx bolts that fit into the seat rails? (4X seat)
1980 FI Spider 2000
1980 FI Spider 2000
Re: Torx Seat Bolts
Thanks Mark however,they are not phillips they are Torx (pronounced "torks") developed in 1967 by Camcar Textron,is the trademark for a type of screw head characterized by a 6-point star-shaped pattern. People who are unfamiliar with the trademark generally use the term star, as in star screwdriver or star bits. The generic name is hexalobular internal driving feature.
Passenger side after Marine Clean applied by itzebtze, on Flickr
they fit into the 4 holes
Re: Torx Seat Bolts
With such a thorough description and history of the torx bolt , I would have thought the size would have been easy for you.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Re: Torx Seat Bolts
Then there are the "Security" Torx, with a pin in the center so you need a special (uncommon availability) driver with a recess in the center to engage the pattern! <{:^)
- 124JOE
Re: Torx Seat Bolts
i bought a set
i am not sure t45 or t50 would be close
Re: Torx Seat Bolts
My 1973 has #3 Phillips. Perhaps they changed to Torx by 1980. As far as I'm concerned, the best replacement is a cap screw. Don't forget the thread sealant. Sorry, I forgot the size.
Re: Torx Seat Bolts
that makes two of us LMFAO! I found that on the web. Sadly my bolts got into the hands of my little mechanic (aka 4 yr old son)dmwhiteoak wrote:With such a thorough description and history of the torx bolt , I would have thought the size would have been easy for you.
- 124JOE
Re: Torx Seat Bolts
8mm 1.25 pitch
try to get stainless seel
its a guess
its a guess
Re: Torx Seat Bolts
I asked for stainless seel (lol) and they asked me if that was the American spelling124JOE wrote:8mm 1.25 pitch
its a guess
Re: Torx Seat Bolts
If you put regular bolts torx or allen, you will have problem because the height of the head is to high and it will interfer with the sliding mecanism
Re: Torx Seat Bolts
I'm quite familiar with torx bolts, but I've never seen them used in a Spider in any location
Re: Torx Seat Bolts
Your right Mark, on my 83 it was metric allen and i needed to cut it because it was too long
Re: Torx Seat Bolts
I meant no dis respect Mark. I merely put the info up to help clarify my request. That being said, when I did have the Torx bolts in there was never any issues with interference.So Cal Mark wrote:I'm quite familiar with torx bolts, but I've never seen them used in a Spider in any location
Re: Torx Seat Bolts
I'm sure they work just fine, my point is that they had been installed by a po at some time
