Last weekend, I bought a 78 Fiat Spider in running condition. Its starts, runs, drives, lights work, etc.. But for it to be a decent reliable vehicle, I've started going through 'fixing' things... My goal is a 'fun' car, maybe some slight restoration, but mostly just for cruising, weekend fun. (I live in Phoenix, AZ, and the weather is just now turning nice for top down/no AC weather.)
FOr starters: The car is somewhat modded. No emissions (no air pump, no cat). Electronic ignition (crane fireball xr700).
Here's what I've done so far:
- CHanged the tranny fluid. Stuff that came out was dark, and thinner than the GL1 I poured in.
- front pads and rotors.. Didn't do the back, cause they didn't have enough rotors in stock. Next weekend.
- Fixed the drivers side door, it would only catch partway. The door would close, but it wouldnt be fully closed.
- Tuned the carb some. It was running really rough at idle. I followed the 'basic tune' instructions on here with success. The PO had the idle turned down to 'no idle', and to get the car to run, they made the mixture extremely rich (1/2 turn from the bottom). Resetting it back to what the docs said made it idle much better.
Current issues:
- Overheating. I suspect that it needs bleeding.. I'll attempt that in the coming week, or next weekend.
- TRanny still seems noisy to me. Maybe its the nature of the beast? I wouldn't look forward to pulling the transmission.
Planned (in the near term):
- Rear pads and rotors
- Change diff fluid.
- Fix pass door, doesn't open from the inside.
- I really need to fix the seatbelts. The current ones are made for someone who's only 3 inches thick (the lap belt is too short, and well, I'm a bit thick). These seem like they are custom belts, so full replace may be necessary.
Longer term:
- The bushings all look like they need replacing. I want to enjoy the car for a few weeks before I attempt those. There's a lot that need replacing.
- FInd and fix the various oil leaks. Doesnt seem to leak much, still would like to seal it up though.
Here's a couple pics.. One is of the bushings that I believe need replacing.. The other is the shock tower which has some rust.. Let me know your opinions please!
