Exhaust smel
lm48
Your car is a: 1979 and 1980 spider
Exhaust smel
Post by lm48 »
I have a 2" custom exhaust system install with out cat. the system has a Botle resonator and an ansa silver line dual tip
When I drive almost at any speed I smell the fumes not much but sufficient to make me a little sick. The exhaust tip bearly exceed the back of the car. If I extend the tips do I get rid of the smell? If I leave anything in the truck after few days will have a heavy smoke smell. Any suggestion ?
TX82FIAT
Re: Exhaust smel
Post by TX82FIAT »
My exhaust tip is about two inches past the end of the car. No exhaust fumes to be concerned about. Have you checked out the system to ensure you do not have an exhaust leak at some point near were the resonator or muffler connects. Also, do you have any white, blue/black smoke coming out of the tailpipe? If no leak it could be a running rich situation. As long as the tail pipe clears the backend you should be OK. Is there a black buildup on the metal around the tailpipe? When your hand a couple inches from the tailpipe while the car is running do you get a good feeling for the exhaust flow. I would not think a 2" custom system without a cat would have an obstruction of the flow assuming both the resonator and ANSA exhaust are 2" inch as well.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
bobplyler
Patron 2022
Patron 2022
Re: Exhaust smel
Post by bobplyler »
You probably have an exhaust leak. I doubt extending the exhaust would do anyhing.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
azruss
Re: Exhaust smel
Post by azruss »
others have complained about exhaust migrating into people space thru the trunk. they claim a downturn exhaust tip elimiated the probem.
IndyMark
Re: Exhaust smel
Post by IndyMark »
In addition to finding any leaks along the exhaust path, I'd make sure you don't have any oil dripping down on the header or pipe in the engine compartment. After I fixed a few leaks and downturned my tailpipe, the level of fumes decreased but I still had some. It's hard to tell the difference between exhaust fumes and smoky oil fumes.
I would double check the distributer seal and the exhaust manifold bolts to make sure they aren't't leaking down on the manifold.
twblanset
Re: Exhaust smel
Post by twblanset »
Mine did this when I put an ANSA exhaust on. Apparently the stock exhaust has a slight downward bend to get the fumes into the flow of air under the car. I did some reading and found some others with straight exhausts that have the same problem. I'm going back to a stock muffler soon.
lm48
Re: Exhaust smel
Post by lm48 »
I did find some leaks along the system. The most interesting one was around the flange between the exhaust manifold and down pipe. I welded two flanges on top of each anther on the top of the down tube. I did not realized that the exhaust fumes will travel around the attachment bolts ( welded only the outside perimeter between the 2 of them) I am also going from 2" to 2 1/4" . The home made silencer will be replace with a vibrant silencer. I will try this way first before installing any turn down tips.
