aux air valve
unplugged
Your car is a: 1981 Spider
aux air valve
Post by unplugged »
I left the aux air valve off when reassembling my engine compartment. I am now having second thoughts as I want to improve idle when first started. Can anyone provide closeup pics on how it is mounted?
Are they are other alternatives that anyone has tried. The car has megasquirt installed so from the control side I have options I believe but the thermally operated bosch valve is appealing from a simplicity stand point.
'81 Spider
narfire
Re: aux air valve
Post by narfire »
The plug connection is pointed to drivers side and is mounted by a couple of short bolts with 10mm heads just behind and on the coolant connection between the cam wheels
SLOSpider
Re: aux air valve
Post by SLOSpider »
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
unplugged
Re: aux air valve
Post by unplugged »
Thanks.
I am looking for an extreme closeup of how it is mounted. I think it is mounted to the coolant neck but that is the part I am missing. My understanding is that the engine heat augments the electrical heater that comes on to slowly shut down the valve which is why I think I need to mount it in some way thermally connected to the engine. OR possible I am wrong and the electrical heater is sufficient to close it.
'81 Spider
wizard124
Re: aux air valve
Post by wizard124 »
no, the voltage applied is all that is needed to close the valve.
http://s940.photobucket.com/user/a7ewiz ... f.jpg.html
This photo shows it completely closed while i was holding the AAR in my hand with the plug connected.
go here: http://www.fiatspider.com/f08/viewtopic.php?f=5&t=22898
