Rear brakes won't bleed
Replaced Rear brake pads and went to bleed system but can't get brake fluid to rear brakes . Disconnected rear brake line from caliper and used vaccuum pump but still could not get fluid compensator bypassed . Help
- spidernut
Re: Rear brakes won't bleed
Make sure that you have the differential supported with jack stands.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
if the compensator is bypassed you may have a hard line that is blocked. Work from the calipers forward, opening connections until you get fluid
On my wife's 80 Spider the hose from the compensator hard line to the "T" on the differential was blocked. If you disconnect the hard line from the hose fluid should flow from gravity.
- RoyBatty
- Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
And to reiterate what spidernut said,
With the car jacked up, it should be lifted and supported by the axle assembly.
Otherwise you could be restricting flow by bringing the rear compensator valve into effect.
