1983 Pininfarina Spider Resto
Posted: Fri Mar 13, 2015 4:55 am
Thought I would share my most recent updates on the restoration of my 1983 Pininfarina Spider.
Here she is in the driveway after her first wash and passing CA smog first try
Pulled the driveshaft after hearing a weird rattle on acceleration.
Center support bearing was shot.
Replaced the center support, u-joints and guibo.
The driveshaft was rebalanced by a driveshaft specialist in socal, said the portion of driveshaft near the rear-axel was way out of balance, I bolted it up and it spins better than ever
The front end was looking a bit worn, decided it was time for a rebuild.
New center steering link.
Steering arm and hub assembly.
Well, I'd be lying if I didn't say I struggled to pry these springs out.
Springs before paint, control arms, and a couple new ball joints.
Sprayed them with high temp yellow paint.
Control arm before paint.
After sandblasting.
Painted all the control arms black.
I bought a really great spring compressor online, was originally marketed for coil springs on Mercedes Benzs but I was so fed up with the spring compressor I had I decided to risk it and buy this one. Wasn't cheap but it made the whole job take 20 minutes and I felt very safe.
Caliper before
A little compressed air and the piston slid right out.
Calipers after being rebuild with new seals and painted.
New brake hoses
Brakes bled, toe-in set
I pulled the A/C unit installed by the dealer, that thing was like 45 lbs. and never even worked! Still need to pull the radiator so I can get the compressor.
She's finally back on the ground!
Drying in the sun after a congratulatory wash
Sandblasted the airbox
Few coats of enamel black
Reassembled with the AFM
Still have to do the rear susspension, rear brakes, radiator, and thermostat so I will make this a running post.
After sandblasting.
Caliper before
New brake hoses
