Diff ideas please
FiatFunk
Your car is a: 1979 Pininfarina 1975 Spider 1990 Lancia
Diff ideas please
Post by FiatFunk »
I need more grip on my 79. I use it in the winter a bit and I'm planning on doing some rallycross in the spring. I currently have some studded tires but grip is still not great. I have a torrent diff that supposedly fits up to 78, took it to the machine shop bit they weren't able to or was going to be too expensive to make work.
Any ideas before I weld up the original diff?
Also looking for ideas to beef up the steering and suspension.
Thank you
Nut124
Re: Diff ideas please
Post by Nut124 »
You drive your Fiat in the show, salt?
Russians make nice aftermarket LSDs for Lada that fit Fiat rear end up to -78. I have one and like it. I used to break diffs every time I got new, sticky tires. The russian one is billet steel vs porous cast iron. Until the late -90's or so, most russian cars had the early Fiat 124 rear axle.
They come in multiple levels of lockup. Need one for street. I have a record of what i bought and received.
You could swap the entire rear axle to the early version.
What is the torrent(?) diff you mention?
FiatFunk
Post by FiatFunk »
Auto correct... I meant torsen diff. It is the Lada torsen. Doesn't fit the 79. I suppose swapping the axle to a 78 or earlier would be a solution if I could find one nearby. There is also tractionconcepts.com which make lsd conversion kits but doesn't look like they have one for the 79.
Yeah I drive it in the winter in the snow and salt. I got it cheap and quite rusted, I did some fairly quick and not too extensive rust repairs and sort of keep on the rust. I drive the integrale in the summer.
FiatFunk
Post by FiatFunk »
Yeah I drive it in the winter in the snow and salt. I got it cheap and quite rusted, I did some fairly quick and not too extensive rust repairs and sort of keep on the rust. It would be cool to keep around for awhile but I wanted something fun to drive in the winter. I drive the integrale in the summer.
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
nevermind. misread.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
