1)headlights- hi/yes; low/yes; tail lights - yes; brake lights - yes left turn - yes; right turn- yes
2)reverse lights - NO
3)horn- yes
4) wipers- yes but they run pretty slowly
5) hazards - yes inside and out
6)gauges- all work including clock but 3 of them were fogged up NOT including the clock...
7)fuses- fusebox has original cover and looks very clean inside and out with no corrosion- no hanging wires etc
9) behind hinges where fender meets radiator mount area - seam visible but slight bondo seems likely under paint
10)looking down either side of radiator - everything looks straight
11)Flex donut looks ok but will change if purchased
12)shock towers- no rust, no distorted metal etc
13)side rails - no rust, straight and good
14)suspension mounting points look clean and strong
15)crossmember looks clean and strong with no cracks or other deficiencies
16)shake wheels- front passenger has slight amount of play- others seem fine
17)oil pan- several dents and oil leakage is evident, not seen at upper engine/manifold but perhaps oil pan gasket? or dipstick area?
18)transmission- did not pop out of any gear- no grinding, seems good
19)no clunking or vibration from rear end
20)emergency brake works
there was some body work done so there is slight bondo but he pointed these areas out. Car has been painted a beautifful Vanilla pearl color about 3 years ago and looks stunning still. He did no mechanical/electrical upgrades except standard stuff like timing belt; electric fuel pump; plugs,wires,cap/rotor/points,fluids. car has great chrome, new rubber all around, great pirellis with much tread left. asking price was 6000 but he went don to 4800. would you go for it? i probably will but it really seems like the TOP of the price range for such a car...i took a few pics with my phone but theyre pretty lame...
Thanks so much for advice
George Ramos
Portland, OR
