Rolled Spider
- spidernut
Rolled Spider
There's a ton of emphasis expressed over having roll bars. Apart from cars used in racing, how many of you have actually seen a Spider that has rolled over? I've never seen one.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re: Rolled Spider
I'm with John on this one...
If you really need a roll bar then you should be using 5 point belts and a helmet.
I had an aluminum one made for my car solely to mount a 3 point seatbelt to. And it looks cool to the teenager in me!
If I ever roll the car I figure I have much bigger problems then the roll bar holding up...
Re: Rolled Spider
the roll bars really stiffen the unibody and result in much flatter cornering. I've seen pics of a couple of them that rolled, but not in person
Re: Rolled Spider
Mark, I can believe that a roll CAGE does stiffen the unibody but the roll bars I see can't do much in stiffening the unibody in a for and aft sense, which common sense, with ragtops, tells me it is needed most. Please tell me what I am not understanding. Do they really do that much for side to side support, or is that just true of rust riddled unibodies which need all the help they can get.
- manoa matt
Re: Rolled Spider
I'm pretty sure it was this forum about 2 years ago. A member let his wife and daughter use his spider for a trip to the grocery store. IIRC they were T-boned in an intersection and the car flipped and landed in a ditch on the side of the road. Without the roll bar they would be about 2 feet shorter. Both survived with a few minor cuts/scrapes.
It wasn't their driving that lead to the rollover as they obeyed the traffic laws. Sometimes its the other guy on the road that gets you.
Re: Rolled Spider
I'll give you that Matt! Hopefully it's always the other guy! Or, better yet, never!!
Re: Rolled Spider
I wouldn't waste time putting a roll bar in a rusted chassis. A roll bar makes a significant difference in stiffness. Sure a complete cage is far better, but a mere roll bar makes a noticeable difference. Everyone that I know of that has installed a bar noticed the added stiffness on their first drive
Re: Rolled Spider
I remember reading that too. It's more likely that you would get rear ended than roll so make sure that your head won't hit the roll bar.manoa matt wrote:I'm pretty sure it was this forum about 2 years ago. A member let his wife and daughter use his spider for a trip to the grocery store. IIRC they were T-boned in an intersection and the car flipped and landed in a ditch on the side of the road. Without the roll bar they would be about 2 feet shorter. Both survived with a few minor cuts/scrapes.
Trey
Re: Rolled Spider
One of our nations premier distance runner, Steve Prefontaine, died at the peak of his career when driving his MGB home from a party, hit a big rock on the edge of a tight turn and flipped the car. it landed on top of him pinning him to the pavement where he suffocated from the weight of the car on his chest. Investigators said he was doing about 20 mph. Probably would have help if he was wearing his belt.
- Your car is a: 1975 Spider
Re: Rolled Spider
in my 20 years of running a fiat salvage yard along with my repair business, we parted out 1800+ fiats only 1 spider had been rolled, no roll bar, it smashed it pretty flat to the door tops, the windshield frame held up supprisingly well, but did smash 70% flat, the driver who was wearing a seatbelt walked away. not sure how but he mush have been face down in the passenger seat.
i also had 1 rolled x1/9 the occupants of that car were not so lucky, they both were un belted and the windshield frame landed on their chests. i personally knew the occupants, drinking and driving was the fault
son has 78 spider
son has 78 spider
- kmac33
- Your car is a: 1974 Spider
Re: Rolled Spider
Adding a roll bar makes a significant difference in chassis stiffness, at least it did with my Spider. That was my motivation for the installation versus roll-over protection.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
- courtenay
Re: Rolled Spider
Aside from everything else, a roll bar in a Spider looks kind of cool. I have one, but have not had the intestinal fortitude to do the cutting and drilling required to install the thing.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
Re: Rolled Spider
this brings up the interesting question of an aluminum roll bar. It should be a decent weight saver. Anyone have an idea of what size tubing would be required.
Re: Rolled Spider
i used 2" tube for the main part and used 1 1/2" for the rear supports
I am sure it is no more than 30lbs and will serve perfectly to hold the seatbelt.
That said, maybe I made the wrong decision and should hav gone with steel???
