Hello,
I am installing the KYB struts in a 81 Fiat spider.
Currently working on fronts.
Struts came out easily, but my question is about the new KYBs. In what order are the new rubber and metal plates that came with the shocks put on the top of the strut?
I arranged them from a pic of another members install but am not 100% confident and the instructions show too many diff configurations.
Also, the lock washer from the OE strut tower does not fit on the threaded top of the strut and the KYBs do not supply one. The nut spins and spins with out one. I purchased some, installed yet the bolt does not tighten completely.
What am I doing wrong here?
KYB install
Re: KYB install
Maybe this will help?
http://www.flickr.com/photos/itzebtze/7966397646/
For the rear
http://fiatspider.com/f08/viewtopic.php ... it=+shocks
For the rear
Re: KYB install
Those were the ones I used, thanks for those!
Well, I guess I wont fret too much about those then so my only issue is why that top nut won't tighten
Also, I really need to keep the upgrades moving along 4uall. What would be on the priority list to upgrade next? It seems like the striaght control arm's bushing is shot on passenger side so I'm guessing those next. Anything else to throw in the shopping cart while I'm down there?
Re: KYB install
On the fronts, the top part of the shock may be turning as you tighten the nut. Try holding on the top part of the shock (through the spring) while tightening. This can also happen in the back.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Re: KYB install
back in the day I did this with pliers and zip tie
Re: KYB install
I would recommend any safety issue be priority oneFiatRG wrote:Those were the ones I used, thanks for those!
Well, I guess I wont fret too much about those then so my only issue is why that top nut won't tighten![]()
Here is a fun little read
https://lh3.googleusercontent.com/1Xltw ... -h424-p-no
these things usually have a start then go off in a million tangents lol
