Big firewall hole seals?
zachmac
Post by zachmac »
So, I've inherited a car with lots of bigopen holes around all the wiring pass throughs in the firewall. Makefor a nice warm smelly, wet passenger compartment. I've searched all of the usual vendor sites but it doesn't look like any one offeres them? Particualrly the one for the big harness on the driver's sidethat passes through just to the right of the steering column (sort of above the gas pedal. What do people do to seal it up (other than that messy spray foam)?
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
spiderrey
Re: Big firewall hole seals?
Post by spiderrey »
If you take pics of the holes, I have the plugs.
wizard124
Post by wizard124 »
Black silicone. If the hole is large, pack in some poly fiber or nylon screen to lend support.
narfire
Post by narfire »
First thing that comes to mind...cut an old inner tube, pop rivet in place and black silicone the edges? Years ago when I was putting my car back together I backed the floor plugs up with roof patch...Smelled a bit for a day or so but after covering it with sound deadener and carpet, no worries or smell. How big is big?
spiderrey
Post by spiderrey »
Sounds like someone just lost the factory plugs.
zachmac
Post by zachmac »
Guys, with all due respect, did any of you bother to read my initial post? :? I ain't talking about lost plugs or holes in the floor. :wink: :wink:
I am talking about the places where the factory passed through the big wiring cable bundles. The are supposed to have some sort of rubber seal around the cabling to minimize the air / water leakage around the cable into the car. You've all got a big wire bundle coming out just left of center facing forward that runs over and along the driver's inner fender and a smaller one that comes out behind and below the overflow bottle and runs down the passenger side inner fender. I have nothing but a hole (no big rubber grommet) on the one coming out of the drivers side BUT a great big wiring bundle! how do I seal around the wiring bundle?
1989 Spider, sold
2008 Mercedes SL65
narfire
Post by narfire »
I did read and I know what you require. The rubber plugs have a slit in them with a corresponding hole to allow the wire loom through. They have a recess in the edge to sit in the sheet metal around the hole. If you can't source one perhaps as mentioned try looking at a piece of inner tube. Now it won't sit obviously, that is why I mentioned pop rivet with some back up gunk.(silicone)
I'll look on my car outside and have a look as to what I have.
zachmac
Post by zachmac »
narfire wrote:I did read and I know what you require. The rubber plugs have a slit in them with a corresponding hole to allow the wire loom through. They have a recess in the edge to sit in the sheet metal around the hole. If you can't source one perhaps as mentioned try looking at a piece of inner tube. Now it won't sit obviously, that is why I mentioned pop rivet with some back up gunk.(silicone)
Thank you, exactly. I wasn't trying to be insulting to anyone, but it seems like someone would sell those seals?
I've checked at least five vendor sites and nothing? I guess a generic one will do of course, I'll just have to do the old upside down under the dash routine to measure and install as the hole is question is just about hidden / inaccessible from the engine side due to the twin weber setup. I'll also of course have to disconnect everything and pull the cable into the footwell first but that is no big deal as I just finished cleaning it up, correcting a lot of PO sins and re-wrapping it.
BTW, short of taking the webers and intake off it is again basically inaccessible from the engine side so I'll have to do whatever I do from the footwell (really don't want to pull the manifold off).
1989 Spider, sold
2008 Mercedes SL65
81SPIDERMATT
Post by 81SPIDERMATT »
cant say which one you will need but I have used this site for some stuff for my other project
http://www.steelerubber.com/firewall-grommets
stpher
Your car is a: 1982 F I spider
Post by stpher »
Hi,
I am restoring a 69 Alfa Spider as well as a 81 Fiat Spider and I think that there are some firewall cable grommets that might work. I can't measure mine until a few days as it is in another storage place.
Check out the Alfa BB for used ones, they do come up
Thanks, Rick
zachmac
Post by zachmac »
81SPIDERMATT wrote:cant say which one you will need but I have used this site for some stuff for my other project
Thank you, I had forgotten all about Steele even though I've used them ion the past.
1989 Spider, sold
2008 Mercedes SL65
dmwhiteoak
Post by dmwhiteoak »
I may have the exact plugs you are looking for. I will looks when I get home and if so I will post pics and send them to you.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
KidDingo
Your car is a: 1981 Fiat Spider 2000 FI 5-spd
Post by KidDingo »
_______________________________________________
Michael
zachmac
Post by zachmac »
KidDingo wrote:Is this what you are seeking?
http://www.autoricambi.us/product/RS1-0 ... l-Grommet/
Thanks but no, that's not it, I need to plug a round hole while passing through a wire bundle. I searched every product under "rubber", "seals", and "electrical" on AR, IAP, VAS, Midwest-Bayless, etc. I think Steele will have what I need.
1989 Spider, sold
2008 Mercedes SL65
