I repeat my earlier post content - PLEASE don't ground the spark plug against "something metal" to test for spark... With any ignition, but especially the computronix. That really hot spark that's one of the big selling points can easily hurt you.
Here's some links for the right tool:
http://m.autozone.com/test-scan-and-spe ... ?location=
http://m.oreillyauto.com/mt/www.oreilly ... p?pt=N0665
Re: Having some issues my with 83... (SOLVED)
- toplessexpat
- Your car is a: 1976 Spider 1800
You can also just put the timing light over each lead in succession and see if you have a blink.
- Patron 2019
I must have missed that post? Good advice, to use a tester though.toplessexpat wrote:I repeat my earlier post content - PLEASE don't ground the spark plug against "something metal"
Poor choice of words on my part "hold the spark plug......"
For me, my arms are too short to hold the plug wire and crank the car from the driver's seat, so I should be safe!
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
But, you can get your little brother to hold the plug wire while you crank. You can usually only do this once.76was124 wrote: For me, my arms are too short to hold the plug wire and crank the car from the driver's seat, so I should be safe!
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
- Patron 2019
Funny, but some of us are slow learners.bobplyler wrote:. You can usually only do this once.
In my case, he got me twice as a kid with a lawn mower engine. It had the old pull start where you wrapped the cord around it and pulled. That was the 1st time holding the plug. Then he said, sorry, he'll turn it slowly by hand this time...''Pop' goes the little bro again!
However, it was a positive life changing experience for me....I learned how a magneto works, and eventually became an electrical engineer.
Previous 76 Spider
Previous 76 Spider
- toplessexpat
I'm laughing! Old stuff you got a little zap, and you learned to NOT do it again. Newer machinery - y'all can do yourself some damage pretty easily!
... and back to the OP - he's got a computronix... Bigger spark = more pain!
A
A
Did you get spark ? My car 1981 Fi died after running for about an hour. it would crank but never turn over. Luckily close to house . Had my son and friends push it back to garage. I eventually found inconsistent weak spark coming from coil (I had son crank ignition while i gapped the cable from coil. Very weak, not consistent spark. I changed wires. No luck. I checked coil resistance....all good. Then I read about ignition control unit. It basically shuts off low voltage side of coil causing magnetic field to collapse; and that generates high voltage discharge. No good way to check it; I did check resistance of "trigger wire" from distributor to ICM and that was normal. I then bought replacement ICM one at autozone for $22.00. (The old one was made by GM and there are many universal ones).ICM is located under coil attached to hear sink. After replacement, everything worked great.
- Odoyle
- Your car is a: 1983 Pinafarina Spider
Well, I replaced the ignition control module and the spark plug wires and she started! Success
Here's the old unit that stopped working.
New ICM unit going in.
Coil with everything back together.
- rjkoop
Excellent. Nice to see the resolution... in case I have a similar issue in the future.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
- toplessexpat
It seems to be "about that time" for many of the ignition modules to fail. I've noticed an upswing in that being the issue in the last 6 months (my 81 included)
Odoyle,Odoyle wrote:Well, I replaced the ignition control module and the spark plug wires and she started! Success![]()
Any chance you have the part number or information on where you purchased the replaced ICM? I'm having similar symptoms and figure I would replace mine as well. Thanks!
Disregard, Found it on Midwest Bayless. Thanks.
Brian
