DIM DASH LIGHTS
JEEPER
Your car is a: 1979 SPIDER
DIM DASH LIGHTS
Post by JEEPER »
Has anyone been able to brighten their dash lights. There isn't a replacement lamp that I can find with a higher lumen output. I replaced a few of the lamps and they are no brighter than the originals. I can't read any of the gauges at night. Any help or suggestions would be appreciated.
Re: DIM DASH LIGHTS
Post by AriK »
Try installing Sylvania Zevo 194. Their cost is in ripoff territory but they're brighter than other LED s. They are also tiny enough that they fit in the gauge housing. You can pick them up at Walmart.
lglade
Re: DIM DASH LIGHTS
Post by lglade »
+1 on the Sylvania Zevo 194 bulbs. I did mine at the same time that I installed a 95-amp alternator, and my dash brightness is what I would consider ideal.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
Frog2Spider
Re: DIM DASH LIGHTS
Post by Frog2Spider »
I replaced the 35 year old bulbs with new regular automotive ones and, wallah!
Bright dash lights!!
It may be that simple?
Dave.
Frog2Spider
'81 - 2000 Spider
njoconnor
Re: DIM DASH LIGHTS
Post by njoconnor »
Noticed the Zevo's in both Walmart and O'Reilly's when I was looking for DRL bulbs for the Jeep GC. Agree with Ari about the pricing. Might want to consider these:
https://www.superbrightleds.com/cat/min ... 4,197,8902:
Put them in the Spider 3 years ago, and I'm very happy with them. And about 1/2 the price of the Zevo's....
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
Re: DIM DASH LIGHTS
The Fiat Dimmer control in the full bright position does not allow the existing bulbs to be full bright. If you connect the dimmer control wire together eliminating the dimmer you might be satisfied with the instrument lighting. If you decide to replace the bulbs with LED's do not replace the alternator warning light in the tach with an LED. The alternator needs an incandescent bulb to operate properly.
