Water pump leak at gasket
- DaveMarcotte
- Patron 2021
- Your car is a: Fiat Spider 1977
So I installed a new water pump and gasket along with my complete engine rebuild. After getting the new coolant in I notice a small puddle starting on the floor under the waterpump. It appeared to be coming at the seem with the pump gasket and block. Removed and reinstalled with new gasket and some gasket sealant. Feel her back up and there it was again. I slow trickle!! Any thought or suggested appreciated. Looking forward to getting back on the road.
Dave From Ottawa, Canada
https://goo.gl/photos/wm7Yzxf1KoB1nwYJ8
- Odoyle
- Your car is a: 1983 Pinafarina Spider
Re: Water pump leak at gasket
Try using a razor blade to remove all of the old gasket, then sand or file the mating surfaces and use a THIN layer of gasket sealant evenly applied to the gasket/ surface.
it is pretty common for the water pump leak to be the pipe for the heater core. The pipes flange is often corroded and pitted also it has a tendency to distort so it is not flat.
- aevansgatech
Whatever you do, don't try to torque it that extra 1/2 turn.. those small bolts can shear off with very little force..
Ask me how I know
Ask me how I know
1979 Spider 2000 (gone)
- DaveMarcotte
- Patron 2021
I ordered a new one for autoricambi. They didn't supply the first one. They suggested one that comes with a lifetime warranty and claim its bullet proof. I'd like to take a moment to say this vendor autoricambi has been nothing but helpful and they're customer services is top notch.
- DaveMarcotte
- Patron 2021
autoricambi water pump did the trick. Don't skimp on 10 bucks, this one is clearly of better quality
- aevansgatech
Good to hear!
- Nanonevol
Did you get A/R's high volume pump, or just their OEM style?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
1985 Jaguar XJ6
1966 BSA Lightning
- DaveMarcotte
- Patron 2021
I had ordered the OEM one but after talking to one of the guys there it was an easy sell to get the better one. Cheers
