82 Spider trunk spring replacement?
TX82FIAT
Post by TX82FIAT »
Folks, I see modifications and adjustments to the trunk spring. However, I have not seen an article that addresses spring repair or replacement.
Current 82 spider is in the last notch position for the trunk and the spring does not have enough tension to hold the trunk up. I'm am holding it up with my bald head or a bicycle pump that seems to always be within arms reach. Just looks bad when the car is shown to someone. I do have a luggage rack adding a little additional weight.
Has anyone found some great solution: turn the spring to obtain more tension, cut the spring -reshape and rehook, integratre some type of wire within the spring that can be tightened, add a miracle lotion that restores tension.
or is it time to find/buy new springs.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
manoa matt
Re: 82 Spider trunk spring replacement?
Post by manoa matt »
If you find you need new springs, I have two sets.
matt.scarton@gmail.com
adrians
Your car is a: 1981 Spider Turbo - missing the turbo
Post by adrians »
I always assumed that twisting the spring and repositioning it would increase the tension.
Otherwise add some gas lifts
See this topic and photo
http://www.fiatspider.com/f08/viewtopic ... ilit=+boot
THE FLEET
2014 Abarth "SS"
NSDave
Post by NSDave »
I recently heated the long end of my springs (red hot) with a propane torch and bent them again. They're now about 3/4" "shorter" than before. Holds the lid up, without my lid (head) helping :lol: ! At the time I thought, this luggage rack must weigh a ton. The trunk lid seems like it should be light.
TX82FIAT
Post by TX82FIAT »
I'm going to try to heat and bend the springs. If that does not work I'll reach out for some springs. Thanks for the feedback and I give it a try this weekend. :D
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
narfire
Post by narfire »
I had the same problem, complete with the head issue :D
I went to the local Lordco here and bought a couple of smaller springs and fed one inside the stock spring and that gave enough pulling power to keep the trunk with the luggage rack up. Don't notice the extra spring unless you know they are there.
SpiderJim
Post by SpiderJim »
narfire wrote:I had the same problem, complete with the head issue :D
Now that is a man with an excellent solution. Do you remember the part number by chance?.
narfire
Post by narfire »
SpiderJim wrote:Do you remember the part number by chance?.
Nope, there were a number to choose from on a board hanging in the corner.
narfire
Post by narfire »
The spring on both side seems to provide just enough to keep the trunk up with a rack. I used straps to connect the spring as I got tired of fiddling with the thing to fit with the existing spring.
htchevyii
Post by htchevyii »
Good thinking, I've been using a metal rod, but i think I'll give your idea a try. Thanks for sharing!
Trey
MNspiderman
Post by MNspiderman »
sheesh. ya learn something everyday. I didn't know spider 2000's had trunk springs. I thought they all were held open with that tiny little rod that likes to slap the inside of your trunk lid. Can I incorporate those springs into my 77 ? :idea:
TX82FIAT
Post by TX82FIAT »
I'm going to try the spring inside the spring solution to slightly increase the tension. I think this will be the best solution as the heating of the spings and re-attachment of them seams problematic and a two man job to re-attach. It looks like these springs can be pulled and attached with the right size.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
