what carb is this
fiat218
Re: what carb is this
Post by fiat218 »
that yours?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
lanciahf
Post by lanciahf »
Jim,
If you put a 1800 manifold on your 79 you will need to make a bracket for the oil dipstick since the 1800 manifold is smaller externally and the dip stick will have no place to bolt to.
You can always get a FI dipstick and fi dipstick cambox bracket.
fiat218
Post by fiat218 »
1980. not 79
they the same?
nothing can just be easy huh
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
WYSpider
Post by WYSpider »
yep
fiat218
Post by fiat218 »
redek wrote:It might be a little bit more to buy it from mark, but if you have any questions about the install he will help you figure it out.
that means alot some of people. that great that he helps
thanks
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
manoa matt
Post by manoa matt »
Send me the extra $70, I'll give you a linkage lever and tell you how to hook it up.
fiat218
Post by fiat218 »
excuse me ? extra 70 for what
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
fiat218
Post by fiat218 »
i want to replace the carb as u seen in the photo, what should i use. i do that a 1800 manifold
and what of all this smog? what do i do with that.
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
lm48
Your car is a: 1979 and 1980 spider
Post by lm48 »
I have a 79 and did this conversion. I removed all the pollution parts. I run a 1600 plaine manifold. I plugged all the holes on the manifolds leaving open only the vacuum for the breakbuster and distributor. It starts at the first kick after the installation. You will need some small modification on the original carb link. I did not have a chance to drive the car because of drive shaft/rust issue so I do not know how the performance will be.
fiat218
Post by fiat218 »
does a person need the vacum advance on the dissy if u switched carbs?
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
124JOE
Post by 124JOE »
yes the dizzy still need it
Newell33
Post by Newell33 »
I purchased my EMPI 32/36 at http://www.appletreeauto.com. At the time it was $215.29 with another 10% off and free shipping. I ended up buying a new spacer and some extra gaskets and had it shipped to my door for right at $203.00 and some change. I don't believe the 10% off deal is still going, but you can still get the carb for $215.29 with free shipping plus whatever gasket(s) you need. I bolted mine on to my '73 with a 1600 and it works like a charm. I fought a 34/34 Weber Interco for several weeks, and can't believe how much nicer the EMPI works.
