Carpet glue
Baz
Your car is a: 1977 Fiat Spider
Carpet glue
Post by Baz »
Can anyone recommend a good carpet glue...spray on or whatever.
My carpet kit was average and tends to come away from the trans tunnel. So Ithink I will need to glue it to the areas where it sags or looks untidy.
Tar
Baz
kmac33
Your car is a: 1974 Spider
Re: Carpet glue
Post by kmac33 »
3M Super 77 Spray on Adhesive. Good stuff!
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
mkmskm
Re: Carpet glue
Post by mkmskm »
How hard was the carpet kit to install? I really need to put better carpet in my car.
kmac33
Re: Carpet glue
Post by kmac33 »
Carpet replacement is easy and straight forward, just time consuming. Remove interior(seats, center console, kick panels, rear panels, etc.), remove old carpet, clean up floor pans (treat rust if necessary), glue in new carpet kit, re-install interior.
Kevin McMullen
1980 Fiat Spider
2013 Subaru WRX
Darsella1
Re: Carpet glue
Post by Darsella1 »
Instead of using glue I would recommend just putting 1/2 inch foam underneath the carpet. It helps smooth out the look and keeps the carpet in place quite nicely. It holds down when you screw the carpets back into place (cut out the same pattern). You can buy the foam from a fabrics store from joanne, etc. Then it is also easily removed, etc.
