Heater Valve, easy to replace?
I'm thinking about replacing my heater valve as I've replaced most of the cooling/heater system and right now I have the coolant drained once again cause I'm putting a 1800 Intake in and need to put in a new radiator as well. I bought new heater hoses. So, is this an easy job to do?
BTW, I noticed the rubber grommet at the firewall which the heater pipes pass through is kind of shot, does any vendors sell a replacement? Thanks.
Re: Heater Valve, easy to replace?
the danger in removing the heater valve is that the mounting studs can break off the core. Be sure to spray a rust penetrant on the studs before attempting replacement.
Your valve looks like one of the original valves that aren't available. The replacement valves are X 1/9 valves and require a slight mod to the heater pipe. The pipe won't line up with the hole in your grommet without bending it. Some owners cut the pipe and use a short piece of heater hose as a flex joint.
Thanks for the advice Mark! Yeah I read that only the x 1/9 valves are made and are used by us spider owners and a slight modification is required to fit.So Cal Mark wrote:the danger in removing the heater valve is that the mounting studs can break off the core. Be sure to spray a rust penetrant on the studs before attempting replacement.
- ga.spyder
If it isnt leaking,I would leave it alone.That may be the worst job I have done on the car.You really have to contort yourself to get at the valve.I would reccomend removing the passenger seat(I didnt).It might help with access.I sprayed the nuts for 2 days before I could get them to budge.Good luck
Craig Nelson
Fling It Around Turns !
Ya, mine all broke off too
Trey
I'll second or third that about if its not leaking don't touch. Marks right about them breaking off.. real easy and the replacement valve needs a bend in the original pipe. I saw a fellow here that cut the pipe and as Mark said used flexable hose.... next time thats what I'll be doing.
- Curly
You guys have it easy with left-hand-drive
You aught to try it with a pedal box and steering column in the way
. Making the X1/9 valve fit and line up through the holes in the firewall can be tricky - I like the idea of cutting the pipe and using a piece of hose. I cut and welded the pipes on mine, but know now what I'll be doing next time
Curly from Oz
Anyone want to guess what happened when I tried to get the nuts off the heater core studs...yup one broke.
I got all them off but last one which was the hardest to reach snapped.
Even with the nuts off I can't seem to seperate the heater pipe from the heater core anyway as I think rust is bonding it. New heater core is now on the list, that will be a good time to replace the heater fan as mine is squeeky. Anyone have instructions on how to install a new heater core? Thx.
So, I have a question. The part that I bought from Vicks said that I may need to bend the inlet pipe by as much as 5 degrees to get the X 1/9 valve to mate up with the core. That's a pretty short piece of pipe but this may still be a stupid question: how do I bend the pipe 5 degrees without damaging it?
- boogiedude
- Your car is a: 1978 spider 1800
Does anyone else see the images in the original post? it looks like some kind of advertisement for a business and a screenshot of someone playing runescape...
Yeah, I'm guessing the original poster has moved the pictures that he originally posted, and these were for some other use.
I just removed them as my old pics aren't there.leftfield6 wrote:Yeah, I'm guessing the original poster has moved the pictures that he originally posted, and these were for some other use.
