Car won´t start.....
- henry
- Your car is a: Pininfarina 1983
After driving with A/C , wipers and radio ON. I have to let the car rest for a while, or it won"t start, it happened a couple times.
Re: Car won´t start.....
Does it turn over or not do anything at all?
- henry
Lights, radio etc, turns on, but won't crank, after resting awhile it does crank.
- azruss
many possibilities here. First i would check battery and ground connections to make sure all is clean and fresh. Next i would look at the starter soleniod. if it is in the "wont run" mode, have someone turn the key to the start position and whack the starter solenoid with the stick. If that kicks the starter on then you have a solenoid problem. (dirty contacts)
could also be a faulty ignition switch, gotta start testing with a voltmeter at connections from the switch to the starter. A common problem area is that connection to the starter that is just along the left inside fender well
