For everyone that hasn't seen inside one, here are pic's. It is real easy to take the top off and fill. If you haven't check you fluid level lately, I suggest you do. Just take the three allen key head bolts off and fill to the top. Make sure the top is clean too and put the bolts back. Take the center bolt off and fill the top. Put the center bolt back on. That's all you need to do.
