So, I've said hello in the intro section. Basically I'm attempting to get my mothers 75 spider back on the road. It was "restored" back in the late 80's. I say "restored" because I think some corners were eliminated altogether, verses simply being cut.
Behind the drivers side wheel, where the shock and spring slide up into the "strut tower" (for lack of a better term). There is a lot of rust. Last night after getting it home I was laying in the street looking at her belly. Admiring her cracked, nearly evacuated bushings (which I have replacements already). When I noticed what looked like a soft spot about 2" above the upper control arm front bushing.
I proceeded to mash at this area using the plastic handle of a screw driver until I'd mashed out everything that would dissolve under light impact.
I was freaked out seeing this! However then I went around to the other side to look for the same issue over there, and found my step father had obviously seen this before. As a lot of this side had been knocked out (as I'd just done) then hit with a coat of Rustolium YEARS ago.
So, The metal edge on that upper drivers side rear bushing is the smallest support structure point at 1.5-ish inches of metal remaining. It feels pretty thick, as if the rusted away portion was mostly protective sheet metal, verses the stonger thicker suspension support area the bushing bolts to.
I've got some great pics but can't figure out how to post them here. My neighbor just brought her dog with an eye infection over to see my dogs. So I don't have time to figure it out right now. Need to disinfect my dogs NOW!
