Door Rattle
opus10583
Your car is a: 1978 CS1
Door Rattle
Post by opus10583 »
Hi,
My car impresses me with its rigidity and lack of door sag and slop but, there's a nagging little rattle of the passenger door, which closes nicely enough, that I imagine is just a matter of fettling the latch and probably lugs: Is there a scheme or protocol for setting the lugs and latch correctly?
Mark
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
azygoustoyou
Re: Door Rattle
Post by azygoustoyou »
You can get inside your door without taking it off. It can be the window tracking either on the sides or the wire track on the bottom of the door that is rattling. Maybe one of those bolts are loose. There are two bolts on the bottom of the door that tighten the wire track. Try them first before taking it apart. Otherwise take off the door panel to see inside. The window track has a bolt at the bottom and top. You can get to them through the existing holes behind the panel. If it's not that, then check out your handle inside to see if the linkage is good. Are you going to the meeting this Sunday?
opus10583
Re: Door Rattle
Post by opus10583 »
azygoustoyou wrote:You can get inside your door without taking it off. It can be the window tracking either on the sides or the wire track on the bottom of the door that is rattling. Maybe one of those bolts are loose. There are two bolts on the bottom of the door that tighten the wire track. Try them first before taking it apart. Otherwise take off the door panel to see inside. The window track has a bolt at the bottom and top. You can get to them through the existing holes behind the panel. If it's not that, then check out your handle inside to see if the linkage is good. Are you going to the meeting this Sunday?
Hi,
Thanks. It's not the windows or linkage, not on that side anyway, it's the door being loose, even though it shuts well.
No on Sunday, unfortunately. Water leak from an apparently stripped heater pipe stud.
Won't be fixed until next weekend...
If nothing else, this car is preparing me for my future ex-wife.
Thanks again,
Mark
manoa matt
Re: Door Rattle
Post by manoa matt »
The door alignment lugs are a must for these cars. New door weatherstripping also keeps the door from rattling by keeping pressure on it.
"If nothing else, this car is preparing me for my future ex-wife."
Just wait until a parts car pops up on your local craigslist, that'll be the day.
opus10583
Re: Door Rattle
Post by opus10583 »
manoa matt wrote:The door alignment lugs are a must for these cars. New door weatherstripping also keeps the door from rattling by keeping pressure on it.
Thanks Matt!
Door gaskets will be on the next VAS order, I've still to get the last onto the car.
Fortunately I can't do a parts car, for the same reason I can't do certain work myself: Apartment dweller.
Until I bought this car I had no need of a house, now I'm looking to rent a garage and a workshop.
Please do let me know if you have a heater pipe bracket, I'll check the car tomorrow.
Mark
azygoustoyou
Re: Door Rattle
If your talking weatherstrip that goes around the door. Buy that from Mcmaster carr. Much cheaper. If you want, I can look up the number to the part.
opus10583
Re: Door Rattle
Post by opus10583 »
azygoustoyou wrote:If your talking weatherstrip that goes around the door. Buy that from Mcmaster carr. Much cheaper. If you want, I can look up the number to the part.
Hi,
Yes, I'd be grateful, but they'll have to be a lot cheaper for me to veer from VAS.
Mark
azygoustoyou
Re: Door Rattle
It was like $26
jimincalif
Your car is a: 1980 FI Spider
Re: Door Rattle
Post by jimincalif »
Hi Brady,
I'd love that part number too. Thx.
Jim
1980 FI Spider
opus10583
Re: Door Rattle
Post by opus10583 »
azygoustoyou wrote:It was like $26
For a pair? That'd be cheaper enough.
What's the #, I had a browse of their site last night and didn't find anything that looked the part.
Mark
opus10583
Re: Door Rattle
Post by opus10583 »
opus10583 wrote: Please do let me know if you have a heater pipe bracket, I'll check the car tomorrow.
Hi Matt,
I'm good on the bracket, just needs to be aligned better.
Mark
azygoustoyou
Re: Door Rattle
Door seal from McMaster Carr
16 FEET 1120A333 Edge-grip rubber seal, Bulb next to grabber, 3/16" edge, 5/8" bulb width.
124JOE
Re: Door Rattle
Post by 124JOE »
i used a seal from a 95 lumina junker
opus10583
Re: Door Rattle
Post by opus10583 »
azygoustoyou wrote:Door seal from McMaster Carr
Thanks Brady,
But they won't quote a shipping fee before placing an order.
I'll stick with VAS.
Mark
azygoustoyou
Re: Door Rattle
ok
