I am cleaning and installing new seals in a set of calipers and one of the rear caliper has damaged threads on the bleeder. The bleeder was tight and worked when I removed it but its is so wobbly when I thread in another bleeder I am worried it might strip when I go to tighten it.
Can some one tell me what the threat size is of a stock bleeder? I plan to install a heli coil.
brake bleeder thread size
- 124JOE
Re: brake bleeder thread size
pull out a different one mabey out of the front
and try it in the back
10 x 1.25mm
I have since been told its not wise to use heli-coils in calipers for brake bleeders. Does anyone know why??
- 124JOE
because you cant drill it out perfectly and cut threads
i have a caliper that had a broken bleeder
i tryed to drill it out on a press and it was still off center
now its junk
now its junk
- 124ADDHE
- Your car is a: 1974 Spider Amalgamation with C40 Solex
mine is 8x1.25. I heli-coiled a bleeder once, always leaked a tiny tiny amount, it lasted until a new caliper arrived
. I should have welded it up and taken it to a machinist, probably not too expensive. Calipers in the states are stupid cheap.
Regards,
Keith Cox
1973 124 Spider
1973 John Deere 500c backhoe
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Keith Cox
1973 124 Spider
1987 Jaguar VDP
2013 passat tdi
2015 cherokee
Thanks everyone for your replies. I decided to try a bleeder repair kit. It's a small bleeder assembly. I need to drill the caliper and tap for and 1/8" nipple pipe thread to install it. I have everything to do this just wondering if anyone has seen them or tried it.
I wouldn't have a problem installing a helicoil in a bleeder. THe old threads are gonna help you get a good center, the aluminum should drill easily. Just don't drill into the bottom of the hole...that taper against the bleeder itself is what seals. The threads do not provide the seal. And I would do heli before some......bleeder repair kit?? And like was said, it is 8x1.25
I made that mistake and sure enough the bleeder leaked,the bleeder did not seal at the bottom. Tried to find longer bleeder screws but was not able to find any locally. I think I still have the caliper if anyone has access to longer threded bleeders.majicwrench wrote: Just don't drill into the bottom of the hole.
Chris
I counter sunk the hole for the bleeder on one of mine so the bleeder could sit in another 1/8 ".
Thanks Kieth, I'll try that
