Oh, I see Mark has new stainless tubes for the engine back to the firewall but SOMEONE should make the lil one comming off the heater but modified/bent for the X19 valves. HINT,HINT!
You're a vendor? And you have the correct valves and not one fitted to an X-19?redauto wrote:if you leave the tube loose (don't forget the gasket) when you put the valve on, and tighten the tube after you have put it through the firewall, you shouldn't have to bend anything. we put that in the instructions when we sell the heater valves.
