Rear disc removal
Rear disc removal
I am replacing discs all around. The front discs pulled off no problem. However, the rear ones will not pull off; either of them. Am I missing some step to get those off?
Re: Rear disc removal
They should come right off, same as the front. are they rusted to the axles?
Trey
When I replaced my front disks, I had to beat them with a dead blow hammer to remove them. I used some anti-seize between the mating surfaced so they wouldn't rust together in the future.
- 124JOE
i used a BIG F HAMMER and hit between the studs to break it free then pull.
A little PB and few swings from my little sledge and it came off. this seems to be a recurring troubleshooting step
