79 2000
After I started the car this afternoon a banging/thumping sound started. Sounds a little like a rod bearing. It accelerates/decelerates with the engine speed.
Don't think it is a rod bearing because it goes away when I push in the clutch.
Any thoughts?
jb
Banging/thumping sound
- Your car is a: 1979 Spider
- Your car is a: 1979 and 1980 spider
Re: Banging/thumping sound
can you record and post the sound?
If it goes away when you disengage the clutch, it's more than likely a clutch or gearbox problem. Possibly the clutch throwout bearing or gearbox input shaft bearing. Does it make the noise while you're driving, or just when the car is stationary?
Mick.
- kmead
It could well be the Guibo which is a flexible coupling in the driveshaft. There is also a drive shaft bearing which can fail in that same area.
Karl
Karl
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
- courtenay
Have you checked to see if anyone is locked in the trunk?
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
- kmac33
- Your car is a: 1974 Spider
Good thought Bruce, but when I lock victims...I mean people....I mean hypothetically, if you locked someone in the trunk, their knocking wouldn't "accelerates/decelerates with the engine". So I doubt this is the causecourtenay wrote:Have you checked to see if anyone is locked in the trunk?
Since it disappears when you push in the clutch, I'd also check the flywheel. Could be occurring at the clutch/flywheel interface.
Kevin McMullen
1974 Fiat Spider - Restoration Complete! But the mods/refinements continue
1980 Fiat Spider
2013 Subaru WRX
1980 Fiat Spider
2013 Subaru WRX
Luckily the victums I keep in the trunk can't move their arms enough in that confined space to make any kind of sound similar to this.
To confuse the problem even more. After I drove the car for about 2 miles after the sound started it went away and hasn't come back.
Could this just be the beginning of the throwout bearing going out?
jb
jb
release bearing shouldn't be turning unless the pedal is depressed or the clutch is adjusted without any free-play. If the car has to move to make the noise, I'd look at the flex joint, tranny mount and driveline
