HI have a 75 spider and went to that it for a drive,as I was backing out of the garage I heard a grinding noise in the steering.I checked the oil in steering box,OK I even adusted the steering box,same,the noise is louder when turning the wheel to the right,sounds like a rubbing grinding crunching noise,loud,jacked up the car and looked at the steering components,all looks good and all is tight,sounds like coming from box,but maybe the idler,Skunked those anyone have any
info on were to start of were to look,this just happened,never heard it before,will be grateful for info.Thank,s Buzzy!
Grinding noise in steering
- Your car is a: 1975 fiat sport spider 1800
Re: Grinding noise in steering
Bearings? take the wheel , brakes and hub off and have a look. No harm if they are ok as you can re-pack them with grease for a piece of mind.
Hi will do but the noise is when Iam not moving,If it were the wheel bearings wouldn,t I hear the noise when moving,or is there alot of pressure on the bearings when turning the wheels,Thank,s will take a look at the bearing and then repack.Thank,s Buzzy!
narfire wrote:Bearings? take the wheel , brakes and hub off and have a look. No harm if they are ok as you can re-pack them with grease for a piece of mind.
- 124JOE
YOU need a hand
someone to turn the wheel
and a lond peice of metal rod
put it on the idler and listen
then the STbox
then the outter ends one buy one
listening all the whille
you will find it this way!
then the STbox
[Thank,s Joe will try that I do need someone to turn the well,but I will used a hose instead of the steel rod,I don,t know if it is the box or the idler,all ball joints and rods are good and tight,its one or the other hope not a box,Thank,s Buzzy!quote="124JOE"]YOU need a hand
then the STbox
you will find it this way![/quote]
then the STbox
Hi Joe lucked out just needed oil in idler,no more grinding noise and wheel turns fine.Thank,s Buzzy!
124JOE wrote:YOU need a hand
then the STbox
Hi Thank,s for the reply,just needed oil in the idler lucked out.all fine now. Thank,s Buzzy!
buzzyb wrote:Hi will do but the noise is when Iam not moving,If it were the wheel bearings wouldn,t I hear the noise when moving,or is there alot of pressure on the bearings when turning the wheels,Thank,s will take a look at the bearing and then repack.Thank,s Buzzy!narfire wrote:Bearings? take the wheel , brakes and hub off and have a look. No harm if they are ok as you can re-pack them with grease for a piece of mind.
- 124JOE
im just glad you got it fixed up
