Shift Boot Removal
Shift Boot Removal
Post by RRoller123 »
How do you get the shift boot cover off? I am changing from tan to black, but there is nothing in any of my manuals on how to get these out, or back in for that matter. Thanks!
Pete
JConnerly
Re: Shift Boot Removal
Post by JConnerly »
Take off the shifter knob
Gently pry up the shifter surround plate( be very careful. It's easy to bend the metal plate that is the backing for the wood trim. I had to completely refurbish mine once I got it up. Need to be careful not damage the consol too.)
Slide the entire assembly up and off the shifter.
Carefully remove the aluminum ring that holds the boot on, you'll want to reuse it.
Place your new boot into the hole and carefully expand the ring to hold the boot in place. This is done from the underside.
Drop the whole assembly back in place and replace the shifter knob.
I didn't replace the plastic clips that holds the plate down. I wanted to be able to get it back up easily.
You probably should replace the inner boot at the same time if the rubber looks damaged.
Thank you! Will attempt this tomorrow.
4uall
Post by 4uall »
Shifter Panel removed by itzebtze, on Flickr
Replace the boot if it looks like this LOL
this worked great from Autoricambi
Inner transmission/ shift boot by itzebtze, on Flickr
Thanks. So there are two boots... hmmm.. I ordered only the outer cosmetic one, will have to see what is going on in there when I pull it apart.
Razooli
Your car is a: 1982 Fiat Spider 2000
Post by Razooli »
RRoller123 wrote:Thanks. So there are two boots... hmmm.. I ordered only the outer cosmetic one, will have to see what is going on in there when I pull it apart.
Be VERY careful when you pry out that panel. Note the cracks and lost vinyl on the console above. Mine has similar cracks there. That covering on the console is very brittle after 30+ years and cracks very easily. The plastic clips on my console which the posts on the panel plugged into shattered with age and now I have some velcro dots holding the panel down. Makes it much easier to remove without damage. You can just grab it under the boot hole and lift it off without prying.
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
Thanks, I think I will just cut away the old boot so I can get at the ring and leverage the mounting plate from the boot side. My console has the same cracks, probably from prior console removals. The console needs to come out and be changed or refurbished and dyed anyway soon enough.
Pete
azruss
Post by azruss »
the inner boot is the important one. it keeps the tranny noise and smells out of the interior.
4uall
Post by 4uall »
agreed, my wife and I were amazed at the difference. The smell, noise & heat were instantly gone. One of the most gratifying repairs to date. :mrgreen:
JConnerly
Post by JConnerly »
Thanks razooli for posting the pictures. I didn't take any while doing mine. Makes it much more clear.
simoboni
Your car is a: 1983 Pininfarina Spidereuropa
Post by simoboni »
JConnerly wrote:Thanks razooli for posting the pictures. I didn't take any while doing mine. Makes it much more clear.
I just got a new inner boot for mine. Now, the silly question is: how do you install it? :) I mean, it looks like I should remove the chrome extension to get the new one in place, since the hole in the rubber is too small...I'm sure a number of you guys have done this before, just can't figure it out!
Simone
Simone
1983 Pininfarina SpiderEuropa
1981 Fiat Spider 2000 CS0 (sold in 2014)
1994 Alfa Romeo Spider (sold in 2005)
2013 Abarth 500c (daily driver)
http://fiatdetroit.weebly.com - http://facebook.com/fiatdetroit
simoboni
Post by simoboni »
problem solved, I figured it out :) Just needed to lube the rubber a bit to get in through, thanks for your help guys!
Simone
dmwhiteoak
Your car is a: 1972 Fiat 124 spider
Post by dmwhiteoak »
Does the foam of the inner boot go towards the top as pictured above or down towards the transmission ? Mine had no boot at all.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
simoboni
Post by simoboni »
dmwhiteoak wrote:Does the foam of the inner boot go towards the top as pictured above or down towards the transmission ? Mine had no boot at all.
Dennis,
exactly as pictured.
Simone
Simone
dmwhiteoak
Thanks Simone.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
