I am considering a Winter project to take off the '81 "boat anchor" bumpers. I have found what appear to be the basis for good working bumperettes using a fabricated bracket with modified existing bumper mounts at:
http://www.awdirect.com/rubber-bumber-g ... /hardware/
To do this, I would prefer to mount the turn signal lamps in the lower outer rectangular holes, which the current turn signal lamps and lenses will not fit without considerable fabrication. Does anyone know a source for reasonably priced lamps that will fit in or over these rectangular areas (possibly surface mount)? (The lens color would not matter as I could use amber bulbs.) Those from Fiat suppliers for earlier models that would appear to fit are about $250 each.
Alternatively, has anyone had luck modifying the existing '81 type lamp assembly to fit this area?
Thanks!
Question on bumper-less front lamps.
- dantye
- Your car is a: all gone
Re: Question on bumper-less front lamps.
Several vendors and a member sell kits.
I used motorcycle rear orange lights and fabricated an extension so they would fill in the hole.
Seem to work so far.
Chris
Chris
- Your car is a: 1985 Spider
There are a couple of people on here that sell turn signals that fill in that hole. One is Mark Allison. I decided to just mount mine behind the grill. Then I put stainless grills over the signal wiring holes. Then I actually used a 4" stainless hose to get fresh air to the air filter from the passenger side hole.
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- dantye
... found another bumperette that might work - a bit larger dimensions:
http://www.northerntool.com/shop/tools/ ... _200310619
- johndemar
I got mine from grittracing (Tony). They weren't expensive, work well,and I like the look.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
your choice of lights really depends on whether you want something that looks like it was designed for the car or was just tacked on
OuchSo Cal Mark wrote:like it was designed for the car or was just tacked on
Online
lol if u seen this 79 i picked upSo Cal Mark wrote:your choice of lights really depends on whether you want something that looks like it was designed for the car or was just tacked on
this P O said he was redoing a vet, i told him from what id seen on this 79 that i hope to god he aint doing the work, and i decided that i will send him all his washers back to him, there was stacks of them on many bolts lol
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Bumperless look with turn signals that I think look period correct, complete with chrome frames - never understood the 'modern upgrade' look for bumperless turn signals.
