Cross member
fiat218
Cross member
Post by fiat218 »
Got a new one from Vicks auto, fit the 79
I am wondering why there a space for that cross member, just one that goes on the driver side, came with it
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
spidernut
Re: Cross member
Post by spidernut »
Is this what you're referencing?
The Spiders with EFI had the frame notched on the passenger side and a plate welded on the cross member to fill in the gap. It makes no sense at all why Fiat would have done this, but here's what it looks like comparing a 79 (the nasty looking one) to an 80+ EFI cross member (a refurbished one from Vick's). For my 79, I had to grind off the welds and remove the plate on the refurbished one so it would fit between the frame rails.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
fiat218
Re: Cross member
Post by fiat218 »
spidernut wrote:Is this what you're referencing?
yes, exactly what i am speaking off. only thing mine is not welded on, so i guess i don't need that
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
spidernut
Re: Cross member
Post by spidernut »
The cross member on the 79 should fit tightly without the plate. You'll know really quickly if it needs it or not once you go to install it....there should be no play between the frame rails and the cross member.
John G.
fiat218
Re: Cross member
Post by fiat218 »
spidernut wrote:The cross member on the 79 should fit tightly without the plate. You'll know really quickly if it needs it or not once you go to install it....there should be no play between the frame rails and the cross member.
Yes thanks,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
