Does it matter? They look the same to me and they fit so I think they're interchangeable. Also does the seat rail adjustment (ie. to slide the seat back and forth) go near the middle console for each seat? I think so but just wanted to be sure.
Questions about seat rebuild
- rjkoop
I took apart my seat to rebuild/POR-15 the frames. Everything is done but I think I may have put the seat cushion/base on the opposite seat base frame. This is the piece I'm referring to...
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Re: Questions about seat rebuild
I have swapped my driver & passenger seats with no issues
was not sure if you were still looking for the bottom seat portion
This may help http://www.ebay.com/itm/Fiat-2000-Spide ... ae&vxp=mtr
I wonder if those rubber straps across the seat bottom are replaceable, and/or available? I'm pretty sure after so many years, mine would be shot, and need replacement. Anyone?
- rjkoop
Got the seat frames rebuilt fine. They look pretty good and re-enforced with new steel in a few sections.
Richard
1981 Fiat Spider
Ottawa, Canada
1981 Fiat Spider
Ottawa, Canada
Would sections of truck inner tube work? Double up if needed.wikkid wrote:I wonder if those rubber straps across the seat bottom are replaceable, and/or available? I'm pretty sure after so many years, mine would be shot, and need replacement. Anyone?
I was also thinking about a leather belt or have them fabricated
When I was building a gyrocopter (many years ago). The seat used truck tire inner tubes. They look similar to the Fiat seat bottom.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
